https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> ams+1st order sigma delta modulator+ no output https://designers-guide.org/forum/YaBB.pl?num=1291862238 Message started by mustangyhz on Dec 8th, 2010, 6:37pm |
Title: ams+1st order sigma delta modulator+ no output Post by mustangyhz on Dec 8th, 2010, 6:37pm I want to simulate a fractional-N PLL. So, I designed a 1st order sigma delta modultor to contol a 2/3 divider. I simulate this modulator in IUS. it works! But, I failed when I simulated it with AMS after making it a cellview. code: `timescale 10ps / 1ps module sdm1(clk, rst, v_out); input clk, rst; //input [28:0] k_in; output v_out; reg v_out; reg [28:0] a1; wire [28:0] s1,q1; wire c1; //assign s1 = 29'b00100110011010011010110101000 + a1; assign s1 = a1; assign c1 = {s1[28]}; assign q1={s1[27:0] }; always@(posedge clk or posedge rst) begin if(rst) a1<=29'h0; else a1<=q1; end always@(posedge clk or posedge rst) begin if(rst) begin v_out<=1'b01; end else begin v_out<=c1; end end endmodule why? anybody can help me? |
Title: Re: ams+1st order sigma delta modulator+ no output Post by mustangyhz on Dec 8th, 2010, 6:38pm the correct output in IUS:[img][/img] |
Title: Re: ams+1st order sigma delta modulator+ no output Post by mustangyhz on Dec 8th, 2010, 6:39pm The test file in ius: `timescale 1ns / 1ps module test; reg clk; reg rst; //reg [28:0] k_dth; reg [31:0] bout_sum, clk_sum, averange; wire bout; modulator M1(clk, rst, bout); always #42 clk = ~clk; initial begin bout_sum = 32'b0; clk_sum = 32'b0; averange = 32'b0; clk = 1'b0; // k_dth = 29'b0; rst = 1'b1; // #98 k_dth = 29'b00100110011010011010110101000; //4cd35a8 #0.01 rst=1'b0; #100000 $stop; end always@(posedge clk or posedge rst) begin if (rst) begin bout_sum = 32'b0; clk_sum = 32'b0; averange = 32'b0; end else begin bout_sum = bout_sum + bout ; clk_sum = clk_sum + 1; averange = {bout_sum,28'b0}/clk_sum; end end endmodule |
Title: Re: ams+1st order sigma delta modulator+ no output Post by mustangyhz on Dec 8th, 2010, 6:41pm the library in cadence |
Title: Re: ams+1st order sigma delta modulator+ no output Post by mustangyhz on Dec 8th, 2010, 11:33pm I have solved the problem ConnRules /usr/ius/tools/affirma_ams/etc/connect_lib/connectLib/ConnRules_18V_full_fast/connect Vsupply=1.8V |
