https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Driven Right Leg circuit https://designers-guide.org/forum/YaBB.pl?num=1293540714 Message started by Victor chan on Dec 28th, 2010, 4:51am |
Title: Driven Right Leg circuit Post by Victor chan on Dec 28th, 2010, 4:51am Here is a picture of a part of a circuit, which contains a right leg driver. My understanding of DRL is a circuit which send a signal to a human body, therefore this human body would have the same 'common voltage' as the circuit, which helps to increase CMRR. However, I would like to know how the below DRL works, especially at the point A, B and C. Also I have seen quite a few of DRL circuits, and they all do some sort of filtering (Low pass filter), I would like to know what value of cut off freq is aiming actually. ![]() |
Title: Re: Driven Right Leg circuit Post by philcorb on Feb 18th, 2011, 6:49am Hi, The DRL circuit essentially places the human body within the a common-mode feedback loop, mainly to minimise 50/60Hz main-hum picked up by the body. The low-pass filtering is for loop stability. Hope this helps |
