https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> RF Power Amplifier IC https://designers-guide.org/forum/YaBB.pl?num=1294826460 Message started by themaccabee on Jan 12th, 2011, 2:00am |
Title: RF Power Amplifier IC Post by themaccabee on Jan 12th, 2011, 2:00am This is about a wide band integrated RF Power Amplifier I was going through the data sheet of MWE6IC9100N & seen the two application notes mentioned i.e. AN1977 & AN1987. I believe that the MWE6IC9100N includes a thermal tracking circuit inside consisting of a tracking FET .And this FET when supplied by a constant Vg in series with a RESISTOR will regulate the IDQ of the RF FET over temperature variations. May be this is silly but I've a following doubt for you, My question is that in addition to the internal thermal tracking FET system supplied by a constant VG through a series RESISTOR , is it necessary to have an additional bias control circuitry( Active bias compensation controller or current source bias controller) mentioned in AN1987 for MWE6IC9100N if we are intending to operate it over a range operating temperatures.If needed then why exactly is so? Any help will be greatly appreciated Thanks & Regards |
Title: Re: RF Power Amplifier IC Post by loose-electron on Jan 22nd, 2011, 12:44pm you need to contact the product engineering support group for the IC. wrong forum |
Title: Re: RF Power Amplifier IC Post by feng lau on Feb 17th, 2011, 6:55pm Amplifiers have a quiescent operating point which will be affected by temperature changes.If amplifier is using in a very wide temperature range, its queescent operating point is changed with temperature.And the amplifter maybe work in a wrong conditions. It is necessary to have an additional temperature compensation circuit as AN1977 & AN1987 give out. :) |
