https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> fork join block https://designers-guide.org/forum/YaBB.pl?num=1295879383 Message started by Deb on Jan 24th, 2011, 6:29am |
Title: fork join block Post by Deb on Jan 24th, 2011, 6:29am Dear All, Please help me in the following issue. I am giving here a code snippet. Please look into this. /////////////////////////////////////////////////////////////////////////////// fork : globalOperator real timeOfStart; integer setMatchHigh; real timeOfMatch; timeOfStart = $abstime; $display("Fork Entered for %d time and timeOfStart for this fork is %f: \n", countStart, timeOfStart); /* forever begin while (($abstime - timeOfStart) < delay) begin if(!setExpr) begin $display("Expr became low before delay time exceeded and hence Thread disabled. \n"); disable globalOperator; end else begin match = 1'b0; end end end forever begin @(cross(($abstime - (timeOfStart + delay)), +1, TimeTolerance)) begin setMatchHigh = 1; $display("setMatchHigh is made high. \n"); timeOfMatch = $abstime; end end if(setExpr && setMatchHigh) begin match = 1'b1; countMatch = countMatch + 1; end @(cross(($abstime - (timeOfMatch + KeepMatchHighTime)), +1, TimeTolerance)) begin if(match) begin match = 1'b0; $display("%d Match was detected and match signal is made low: \n", countMatch); disable globalOperator; end end join end ////////////////////////////////////////////////////////////////////////// Within the fork block, after each thread is created, I want to check setExpr for delay value after timeOfStart. For that I have used the while loop but its basically stalling the simulation. How can I do that within the fork block? Please suggest. Also please suggest how can I use a cross statement within the fork block. Thanks in advance for your kind support. ------------------------------ Thanking you, Yours sincerely, Debjit ====================== Debjit Pal |
Title: Re: fork join block Post by Marq Kole on Feb 2nd, 2011, 6:17am There is no delay in your while loop, so it will continue to evaluate the code, never progressing through time. If you add a delay anywhere in the loop the while loop will probably work. However, this is a kind of "polling"technique which is quite costly in terms of performance and only as accurate as the delay value you specify. You might want to rework this into an event-driven test case, for instance an event that triggers on any change in setExpr. Cheers, Marq |
Title: Re: fork join block Post by Deb on Feb 2nd, 2011, 7:42am Hi Marq, Yep !! You are very correct.. I am implemented it already in other fashion with a concept of loop unrolling.. But anyways.. Thanks for your kind support... Yours sincerely, Debjit . Debjit Pal. |
