https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> 45nm in LTspice https://designers-guide.org/forum/YaBB.pl?num=1298060391 Message started by koma on Feb 18th, 2011, 12:19pm |
Title: 45nm in LTspice Post by koma on Feb 18th, 2011, 12:19pm Dear all I am trying to build an analog circuit using 45nm technology using LTspice simulator.the problem is when I include the 45nm tech file(Techfile_45nm.scs from the PTM(attached with this post)) I am getting this error from LTspice"simulator:missing node(s)".when I try another technology files like IBM90nm.txt it works fine. can any one advise me about this problem. regards, |
Title: Re: 45nm in LTspice Post by Geoffrey_Coram on Feb 22nd, 2011, 5:34am Does LTspice read Spectre format files? I would: a) rename the file to Techfile_45nm.sp b) delete "simulator lang=spice" c) if that's not enough, try removing all the blank lines and comment lines from within each model card (leave a blank line before the pmos card, but each line from the .model to the last line of the model card should start with "+") |
