https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Spectre Turbo Parasitic Reduction Netlist https://designers-guide.org/forum/YaBB.pl?num=1298386393 Message started by Berti on Feb 22nd, 2011, 6:53am |
Title: Spectre Turbo Parasitic Reduction Netlist Post by Berti on Feb 22nd, 2011, 6:53am Hi all, It is mentioned in a White Paper of Cadence that Spectre Turbo Parasitic Reduction does not change the netlist. Is there a way to compare the netlist with the actual netlist after parasitic reduction (which is used for the simulation)? Or in other words: Can I find out how the netlist has been changed by the parasitic reduction? Thanks for help! |
