https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> Selecting Module View hierarchically https://designers-guide.org/forum/YaBB.pl?num=1298886996 Message started by Berti on Feb 28th, 2011, 1:56am |
Title: Selecting Module View hierarchically Post by Berti on Feb 28th, 2011, 1:56am Hi everybody, Is it possible to define that module view of the digital cells are used for an entire sub-block, while schematic view are used for other digital cells? In the hierarchical editor I can either define all digital cells to use module view, or I define it for individual instances (but that is tedious to do for a large digital block). Is there a way to define that hierarchical, e.g., all instances in a particular circuit block use module view? |
Title: Re: Selecting Module View hierarchically Post by boe on Mar 3rd, 2011, 4:06am Which tools do you use? |
Title: Re: Selecting Module View hierarchically Post by love_analog on Mar 3rd, 2011, 2:07pm In AMS designer you should be able to pick each module view seperately. |
