https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> phase responce of a system https://designers-guide.org/forum/YaBB.pl?num=1301400727 Message started by raja.cedt on Mar 29th, 2011, 5:12am |
Title: phase responce of a system Post by raja.cedt on Mar 29th, 2011, 5:12am hi, can any one please tell me is there any way to predict phase response from step response of a system? Thanks. Raj. |
Title: Re: phase responce of a system Post by Rakesh on Mar 29th, 2011, 7:02am Hi, yes, You can measure the rise time and the settling time of the step response and from there you can predict the zeta and natural frequency of second order system. Once this is know i think phase response is known. i assume you approximate your system as second order system Rakesh |
Title: Re: phase responce of a system Post by boe on Mar 29th, 2011, 8:30am Hi raja.cedt, Every L(inear)T(ime)I(nvariant) system is exactly defined by its step response. All you need is the Fourier transform of your step response... B O E |
