https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> characteristic impedance calculator https://designers-guide.org/forum/YaBB.pl?num=1302048042 Message started by vp1953 on Apr 5th, 2011, 5:00pm |
Title: characteristic impedance calculator Post by vp1953 on Apr 5th, 2011, 5:00pm Hi I am wondering if there are any calculators out there that will provide the width for a 50 ohm transmission line, for different FR4 board thicknesses. Thank you in advance. |
Title: Re: characteristic impedance calculator Post by apprentice on Apr 5th, 2011, 8:00pm AWR microwave office - txline Agilent ADS - line cal |
Title: Re: characteristic impedance calculator Post by vp1953 on Apr 6th, 2011, 9:50am Hi Apprentice, Thanks very much! |
Title: Re: characteristic impedance calculator Post by loose-electron on Apr 8th, 2011, 2:06pm There are online calculators on some PCB sites for this Go do some searching, its out there |
Title: Re: characteristic impedance calculator Post by rfcooltools.com on Apr 18th, 2011, 5:50pm vp1953, You can use the rfcooltools for this by placing a series t-line component between two ports and playing around with the Height , Er and Width. It is pretty basic. I have not implemented loss tangent yet but that effect is usually a second order effect for most applications. http://rfcooltools.com |
