https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Schottky diode based Sense Circuit... https://designers-guide.org/forum/YaBB.pl?num=1302220954 Message started by george on Apr 7th, 2011, 5:02pm |
Title: Schottky diode based Sense Circuit... Post by george on Apr 7th, 2011, 5:02pm Hi, I am new to circuit design dealing with high-speed signals and I need help finding a solution to what is a simple problem for most of you. I need a high-Z voltage sense circuit for a high-speed I/O line. I have heard this can be done with a Schottky diode but I am not sure how. The point of the circuit is to probe a signal without disrupting it. Any ideas or directions? Thanks, -George |
Title: Re: Schottky diode based Sense Circuit... Post by Rakesh on Apr 7th, 2011, 7:29pm What is the signal u r looking at like wat is the magnitude range etc |
Title: Re: Schottky diode based Sense Circuit... Post by george on Apr 8th, 2011, 9:33am It is for a pass-through/break-out board for Display Port. The peak to peak of the signal shouldn't be more than 1V. However, I would like to spec it at 2V for extra resilience. The signal is differential if you aren't aware of this. It is like USB. |
Title: Re: Schottky diode based Sense Circuit... Post by loose-electron on Apr 8th, 2011, 1:54pm PCB or IC level design? Digital sense output or buffered analog signal out? Maximum frequency? Accuracy of sensor (offsets?) To be helpful, need a lot more info to define the problem. Jerry |
