https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Spectre error https://designers-guide.org/forum/YaBB.pl?num=1302749400 Message started by abhishek on Apr 13th, 2011, 7:50pm |
Title: Spectre error Post by abhishek on Apr 13th, 2011, 7:50pm Hi, i am getting this error while running simulations using spectre. I have included the model library. Error found by spectre in `nhvtlpbc', during circuit read-in. "input.scs" 13: `nhvtlpbc' is being redefined. Error found by spectre in `phvtlpbc', during circuit read-in. "input.scs" 20: `phvtlpbc' is being redefined. In the netlist the error is in the line subckt nhvtlpbc d s sub g tbody ends nhvtlpbc and similar for nmos device, I am not sure what is causing the error, I have tried commenting out line 13 and 20 to see if the error goes, but it doesn't. Any help in this ? I am running virtuoso 5.1.4.1. Thanks, |
Title: Re: Spectre error Post by sheldon on Apr 13th, 2011, 8:26pm Greetings, First guess, look in the include files, is there another subckt/model defined with the same name? Best Regards, Sheldon |
