https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Physical Verification, Extraction and Analysis >> HELP TO SOLVE ERROR IN ABSTRACT EDITOR OF CADENCE https://designers-guide.org/forum/YaBB.pl?num=1302763060 Message started by VINAY RAO on Apr 13th, 2011, 11:37pm |
Title: HELP TO SOLVE ERROR IN ABSTRACT EDITOR OF CADENCE Post by VINAY RAO on Apr 13th, 2011, 11:37pm I tried out layout (for UMC180nm) in cadence but unable to solve some errors while generating LEF file. DRC,LVS, Parasitic extraction these are all passed. Even i am able to generate .gds file. Then i went for LEF from abstract but getting error which i attached to this topic. I did layout for simple inverter then i am generating layout by using "Gen from Source" in layout XL.After everything (DRC,LVS,extraction, post layout simulation) been done, i selected abstract editor tool -> create abstract- finally it is generating error. I tried to solve by dumping technology file (technology.tf, by using TECHNOLOGY FILE MANAGER) into current working directory but by this also i got the same error. I am not understanding whether the problem is with the technology file which is given from foundry or some thing else. If any one could reply me it would be really helpful. |
Title: Re: HELP TO SOLVE ERROR IN ABSTRACT EDITOR OF CADENCE Post by ywguo on Jul 19th, 2011, 11:43pm Hi, I come across the same problem when I generate LEF for a layout (SMIC 0.18um CMOS process). I think this occurs because the technology file does not define routing layer and via. Have you worked out this issue? I am trying my best now. Yawei |
