https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> regulator model convergence problem https://designers-guide.org/forum/YaBB.pl?num=1308467178 Message started by ywguo on Jun 19th, 2011, 12:06am |
Title: regulator model convergence problem Post by ywguo on Jun 19th, 2011, 12:06am Hi Guys, I tried to simulate an 8MHz crystal oscillator with the current limiting voltage regulator. That regulator is one of Ken's Verilog-AMS model. http://www.designers-guide.org/VerilogAMS/functional-blocks/regulator/regulator.va The average current consumption of my 8MHz crystal oscillator is more than 40 μA. Its peak current is near 80 μA. It runs off the regulator output. When I set vmax = 1.9V, and imax = 1mA, the simulation looks good. Then I want to check what happens if the current is limited by the regulator. I set imax = 60 μA and vmax = 1.9V. The simulator failed to converge in transient analysis. I tried to set timeTol and exprTol in the cross function. For example, @(cross((v-vmax)/vmax - (i-imax)/imax, 0, 1e-6, 1e-3)) ; But it failed. How do I make an estimation about the tolerances for this simulation? The output log file is attached. Any comments are appreciated. Yawei |
Title: Re: regulator model convergence problem Post by ywguo on Jun 19th, 2011, 12:20am The following is the waveform of avdd current, voltage, and clock output of the crystal oscillator. It is weird that avdd current has a big spike, a few hundred ampere, before the convergence failure. Yawei |
