https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> effect of delay in feedback system https://designers-guide.org/forum/YaBB.pl?num=1309675728 Message started by raja.cedt on Jul 2nd, 2011, 11:48pm |
Title: effect of delay in feedback system Post by raja.cedt on Jul 2nd, 2011, 11:48pm hi, can any please tell me analyze system feedback system with ideal delay block. Because i am getting some e-st terms Thanks, |
Title: Re: effect of delay in feedback system Post by rfidea on Jul 3rd, 2011, 1:52am The delay behaves as a phase delay with unity gain. The mathematical description is exp(-i*2*pi*f*T). The delay will lower your phase marginal with its phase delay at your loopgain crossing frequency. For example, if your crossing frequency is 1GHz and your delay is 0.1ns you will lower the phase margin with 360*0.1n*1G=36deg. |
Title: Re: effect of delay in feedback system Post by buddypoor on Jul 3rd, 2011, 1:59am raja.cedt wrote on Jul 2nd, 2011, 11:48pm:
Yes, the formula from rfidea tells you that the delay causes a phase shift that is frequency dependent. A very critical situation for all feedback systems - in particular in control electronics. |
Title: Re: effect of delay in feedback system Post by raja.cedt on Jul 3rd, 2011, 10:32am hello allr, yes, i agree with formula. 1. we can say that delay will decrease phase margin, So can i conclude by increasing slightly delay in the loop will give better settling time (if system has better phase margin before introducing delay) 2. I have so much replica delay in pll feedback path, now i want to introduce some delay in behavior model. How to introduce that (i know that some how we have to introduce e^-st) Thanks, Raj. |
Title: Re: effect of delay in feedback system Post by rfidea on Jul 3rd, 2011, 1:12pm 1. I not think you get that improvment. The faster settling time you get with a lower phase margin is due to the fact that you increasing the closed loop bandwidth by increasing the open loop gain. You do not get this with a pure delay. 2. You need to tell which type of behavoural models you are using, veriloga, vhdl ... ? |
Title: Re: effect of delay in feedback system Post by raja.cedt on Jul 3rd, 2011, 8:04pm hi rfidea, i am using spectre circuit simulator and there some how i am modeling every block with vcvs and vccs Thanks, raj. |
Title: Re: effect of delay in feedback system Post by buddypoor on Jul 3rd, 2011, 11:12pm raja.cedt wrote on Jul 3rd, 2011, 10:32am:
to 1.): More delay for a shorter settling time??? Can you verify this statement? to 2.): You can approximate the exponential function using the Pade-Approximation. |
Title: Re: effect of delay in feedback system Post by raja.cedt on Jul 4th, 2011, 2:21am hello buddypoor, I am guessing through some intuition. Please find the attached plot. Here let say you have given 1v signal, output will reach K volts and feedback voltage will be 1. Now if you apply 0 volts, O/P has to reach 0 . So steeling depends on the forward path integrator now. If you have any delay it will keep fb voltage still 1 so that integrator will see 1 volt and it decelerates fastly, where as if you have don't have any delay changes at the o/p will immediately reflect at input. Please note that in the above analysis i am assuming that delay is small such that it won't make your system unstable. Buddypoor some how i am trying to derive some expressions but i am not able to..can you give any suggestion, whats the final Goal is without delay in the loop gain we will get some poles, but with delay may be poles which are far from with delay case. Sorry for the big post. Thanks. |
Title: Re: effect of delay in feedback system Post by Alexandar on Jul 4th, 2011, 4:05am You could try linearizing the exp(s*tau). You'll get a LTI system which is much easier to analyze. That is, if you are interested in the small signal response. |
Title: Re: effect of delay in feedback system Post by buddypoor on Jul 4th, 2011, 9:51am raja.cedt wrote on Jul 4th, 2011, 2:21am:
Hello raja.cedt I am very sorry but I do not understand what your problem is now. I don't get the meaning (problem description) of the first part and also not the more general question at the end of your posting. Let me state the following: I assume you know about the meaning of the loop gain and the stabilization criterion (Nyquist) associated with it. Because in this respect the phase plays a major role, of course any delay effects within the loop are very critical because they introduce additional phase shifts into the loop. And this phase shift is proportional to the frequency! That means - as far as the integrator with a delayed feedback is concerned (your example): The circuit is stable only if the unity-gain frequency of the integrator is smaller than the frequency that introduces an additional phase shift of -90 deg due to the delay element. This results in a total phase shift of -180deg (plus -180 deg due to neg. feedback at the summing node). Does this answer some parts of your question? |
Title: Re: effect of delay in feedback system Post by raja.cedt on Jul 4th, 2011, 11:15am hello buddy poor, thanks i understood . |
Title: Re: effect of delay in feedback system Post by nrk1 on Jul 5th, 2011, 12:03am raja.cedt, The system you show is analyzed in detail in the first few lectures at the link below. You get a delay differential equation whose solutions are (combinations of) exp(st) as usual. Explanation and analysis of this in time domain give a quick intuition to all results regarding negative feedback amplifiers and delay. http://www.ee.iitm.ac.in/~nagendra/videolectures/doku.php?id=ee539_2011:start Quick summary of responses to a step: * zero delay: exponential build up with a time constant 1/omega_u * delay < 1/e/omega_u: Equivalently a two pole system(two real solutions for s); No overshoot---equivalent to overdamped two pole system * delay = 1/e/omega_u: Two identical solutions for s; Fastest step response without overshoot---equivalent to critically damped two pole system * 1/e/omega_u < delay < pi/2/omega_u: Infinitely many complex conjugate solutions for s, all in the left half plane; The lowest frequency solutions dominate---equivalent to underdamped two pole system * pi/2/omega_u = delay: Infinitely many complex conjugate solutions for s, with at one pair on the imaginary axis; unstable * pi/2/omega_u < delay: Infinitely many complex conjugate solutions for s, with at least one pole pair in the right half plane; unstable * A "reasonable" amplifier without too much ringing while settling: delay < 0.5/omega_u A real system with many parasitic poles behaves quite similarly to this. Graphs are shown in the videos at the link above. Alexandar, linearizing exp(-s*tau) as 1/(1+s*tau) doesn't give the small signal response. The approximation is OK for very small delays, but gives incorrect results for critical damped case etc. and doesn't predict instability for any value of tau. linearizing it as (1-s*tau) does predict instability, but again at the wrong value of tau I believe. Cheers Nagendra Nagendra |
Title: Re: effect of delay in feedback system Post by Alexandar on Jul 5th, 2011, 4:26am nrk1, you could linearize it as (1-s*0.5*tau )/(1+s*0.5*tau). Deriving the equations for the loopgain, I guess you'll end up with a two pole system with a zero in the right halfplane. So depending on the gain, you could get an instable system. So there you go =) |
Title: Re: effect of delay in feedback system Post by buddypoor on Jul 5th, 2011, 5:51am Lex wrote on Jul 5th, 2011, 4:26am:
Just for clarification: The above formula is identical to the Pade-Approximation as I have mentioned in my posting before. |
Title: Re: effect of delay in feedback system Post by raja.cedt on Jul 5th, 2011, 8:58pm @buddypoor: yes man..it's same as pade approximation, with higher level of abstraction. @ alexender: that approximation will give you correct result for very small delay because exp(-x)~1-x only if x is lower. Thanks. |
Title: Re: effect of delay in feedback system Post by raja.cedt on Jul 7th, 2011, 11:06pm @nrk1, according to your post i verified in simulation and came to know that max allowable delay in loop is .5*wu. For a first order system Phase margin is 90(ideally speaking), so with delay before going in to oscillations we can add 90deg Phase hence max delay is .25*wu. But how .5Wu is working fine. Is this phase to delay conversion is wrong? Thanks. |
Title: Re: effect of delay in feedback system Post by nrk1 on Jul 11th, 2011, 5:27am With 0.5/omega_u, the extra phase at omega_u is 1/2 radians or 28 degrees, leaving a phase margin of 62 degrees. Nagendra |
