https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Using transient simulation to predict jitter https://designers-guide.org/forum/YaBB.pl?num=1312076379 Message started by YCY on Jul 30th, 2011, 6:39pm |
Title: Using transient simulation to predict jitter Post by YCY on Jul 30th, 2011, 6:39pm Hi Frank I read your post in previous thread http://www.designers-guide.org/Forum/YaBB.pl?num=1224609785/25#25 You mentioned that jitter could be analyzed using transient noise, and it has a good matching with that of pnoise. I don't know how to calculate jitter using transient simulation, because in the eyeDiagram, Ican only see the peak-to-peak jitter. I have no idea how to get the rms value. Could you please provide more information about how to do this? Thanks a lot. regards, YCY |
Title: Re: Using transient simulation to predict jitter Post by sheldon on Aug 1st, 2011, 4:24am YCY, You don't specify what you are looking for, if you are looking at jitter of a clock signal in Virtuoso, then try using the calculator rms( period_jitter(Vsig) - avg( period_jitter(Vsig)) Best Regards, Sheldon |
Title: Re: Using transient simulation to predict jitter Post by YCY on Aug 1st, 2011, 7:28pm Hi, Sheldon Thanks for your reply. I just wonder how to use transient simulation to find out jitter. For example, if I connect a chain of inverters and apply a clock signal at input, then how do I get the edge-to-edge jitter using transient simulation? Frank mentioned that one can use eyeDiagram function in the calculator to do so, and I am curious how to do that. BTW, you said I can use "rms( period_jitter(Vsig) - avg( "period_jitter(Vsig)) in the calculator. Is period_jitter() a calculator function? I cannot find that in the calculator in Spectre. Thanks regards, YCY |
Title: Re: Using transient simulation to predict jitter Post by ywguo on Aug 7th, 2011, 5:21am Hi YCY, period_jitter is a function in calculator for VIVA. VIVA is available if you have IC6.x. However, period_jitter is not present in wavescan. Yawei |
Title: Re: Using transient simulation to predict jitter Post by YCY on Aug 8th, 2011, 9:43pm ywguo wrote on Aug 7th, 2011, 5:21am:
Hi, Yawei Thanks for your response. No wonder I cannot find it in my calculator (I use IC5141). Nonetheless, I am still curious about how to get jitter using eyeDiagram(). Does anybody know how to do that? regards, YCY |
