https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Typical Power supply value for 0.18um Technology for TransImpedance Amplifier https://designers-guide.org/forum/YaBB.pl?num=1312424382 Message started by Larry_80 on Aug 3rd, 2011, 7:19pm |
Title: Typical Power supply value for 0.18um Technology for TransImpedance Amplifier Post by Larry_80 on Aug 3rd, 2011, 7:19pm Hello All, Could someone pls tell me the typical VDD value for a highspeed >2.5GHz transimpedance amplifier(Inductor free)? I am embarking on a self project and want to make sure i am using typical value for my power supply. Is 2V an OK value? May i add also what a typical value for the input diode capacitance might be. |
Title: Re: Typical Power supply value for 0.18um Technology for TransImpedance Amplifier Post by aaron_do on Aug 3rd, 2011, 8:08pm Hi, Its mainly determined by the stress that the devices can handle. I think 0.18 um technology is typically 1.8 V and 3.3 V for high voltage devices. 2 V may cause long term stress issues especially for digital circuits. Not sure about input diode capacitance...probably need to check some publications, or if possible, manufacturer data. regards, Aaron |
Title: Re: Typical Power supply value for 0.18um Technology for TransImpedance Amplifier Post by loose-electron on Aug 4th, 2011, 7:06am input diode capacitance will be tightly tied to ESD capabilities. need to check for specifics of I/O cells. |
