https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> working with wreal variable https://designers-guide.org/forum/YaBB.pl?num=1312886872 Message started by SARAM on Aug 9th, 2011, 2:47am |
Title: working with wreal variable Post by SARAM on Aug 9th, 2011, 2:47am I have a file that contains my waveform. and i want to feed it to my system at certain clk time. i wrote this code : sometime when i check the the output some of samples are missed. and they are not sync with the posedge clk.( wreal D flipflop) module wrealdff(in,out,clk) input clk,in; output out; wreal in,out; real temp; always @(posedge clk ) temp=in; assign out=temp; endmodule is this code correct? please help |
Title: Re: working with wreal variable Post by boe on Aug 9th, 2011, 5:30am SARAM, Tool? Version? B O E |
Title: Re: working with wreal variable Post by SARAM on Aug 9th, 2011, 8:12am I use Verilog AMS in Cadence Version 5.10.41 |
Title: Re: working with wreal variable Post by boe on Aug 9th, 2011, 10:33am SARAM wrote on Aug 9th, 2011, 2:47am:
Code:
Then it seems to work with Cadence (IUS 9.20). B O E |
Title: Re: working with wreal variable Post by SARAM on Aug 10th, 2011, 12:08am Hi BOE, Thanks. sorry I forgot to put ';'. attach please see the input source and use this code and see the output. the clk frequency is 61.44 MHz. the input data also sample at this clk before. when I checked the input output and clk and display the point in the figure. the output is not sample at clk and sometime miss some points. of rising edge. Thanks in advance |
Title: Re: working with wreal variable Post by boe on Aug 10th, 2011, 2:02am SARAM , Testbench? Which version of AMS Designer do you use? OK, I only ran a few clock cycles with my own TB, but it seemed to work fine. B O E |
Title: Re: working with wreal variable Post by SARAM on Aug 10th, 2011, 2:53am Hi BOE, Attached you can see test bench and results, you can see the module does not operate at the clk and the output is totally distorted. I use IUS 8.2. Thanks |
Title: Re: working with wreal variable Post by boe on Aug 10th, 2011, 5:55am Hi SARAM, For me it works (IUS 9.20) - clk period is 2 us. See Image. Do you use AMS? Do you use sample&hold mode for waveform display? B O E |
Title: Re: working with wreal variable Post by SARAM on Aug 10th, 2011, 6:08am Hi, yes I use AMS but I did not see the wave form in simvision. I run in batch mode not inteactive. and use it to display figure. when I check the signal you can see it is not correct. I do not use S/H. How do you read file to AMS? I use vpwlf. would you please try to read it and display the point like me an you will see the effect. Thanks |
Title: Re: working with wreal variable Post by boe on Aug 10th, 2011, 6:21am SARAM, If you use vpwlf, you need an E2R connect module to convert the output voltage to wreal. Which connect rules do you use? Note that the default connect rules use the absdelta event with delta=Vsup/64. Your input signal is probably too small compared to this delta. B O E [Added] PS: I suggest to try file I/O ($fopen, $fscanf, $fclose) for stimulus generation in your case. |
Title: Re: working with wreal variable Post by SARAM on Aug 10th, 2011, 7:00am I think I used default connect rules. Type: built_in Rules Name: ConnetRules_18V_full_fast how can i change this value? one more thing, the file is sampled equi distances but when i see the figure and show the the points i see variable sampling that somehow it is not related to my input file. why is that? I am sorry that asking lots of questions. Thanks |
Title: Re: working with wreal variable Post by boe on Aug 10th, 2011, 9:44am SARAM wrote on Aug 10th, 2011, 7:00am:
Quote:
For more details refer to Verilog-AMS LRM on absdelta events. B O E |
Title: Re: working with wreal variable Post by SARAM on Aug 10th, 2011, 11:58pm Hi, Thanx for your help. I have tried to use the system task function $fread It works pretty fine. Thanks once more |
