https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Class F Power amplifier with no offchip components https://designers-guide.org/forum/YaBB.pl?num=1313165246 Message started by vp1953 on Aug 12th, 2011, 9:07am |
Title: Class F Power amplifier with no offchip components Post by vp1953 on Aug 12th, 2011, 9:07am I was wondering if it is possible to make a class F power amplifier with no off chip components at all. Most manufacturers spec show that off chip filtering is always required - example numbers are for 14dBm transmit power at 915M, with offchip filtering, the second harmonic is at -50dBm. Any reference for a completely integrated Class F power amp would be appreciated. Thank you. |
