https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> How to force an unknown state to 0V or 1.8V? https://designers-guide.org/forum/YaBB.pl?num=1316767053 Message started by Kamal on Sep 23rd, 2011, 1:37am |
Title: How to force an unknown state to 0V or 1.8V? Post by Kamal on Sep 23rd, 2011, 1:37am Hi all, I am running mixed simulations with AMS-ADE and I have an unknown state on one output of a digital block (output of a flip-flop before the reset). How to force this unknown state to 0V or 1.8V? During the simulation I use the "ConnRules_18V_full_fast". |
Title: Re: How to force an unknown state to 0V or 1.8V? Post by boe on Sep 23rd, 2011, 1:57am Kamal, There are several options, you could e.g. change your connect module or use the force/release commands to override the signals at the beginning. B O E |
Title: Re: How to force an unknown state to 0V or 1.8V? Post by Kamal on Sep 23rd, 2011, 3:00am Thanks for your answer BOE, however could you be more explicit. In fact, I am a beginner with mixed-simulations & AMS. In the "Cadence AMS Simulator User Guide" there are force Command Examples but I do not understand how to use those commands in ADE. |
Title: Re: How to force an unknown state to 0V or 1.8V? Post by boe on Sep 23rd, 2011, 4:33am Kamal, If you use interactive simulation mode (Netlister & Run Options) the simulator starts with GUI, so you can enter commands in the console. B O E |
Title: Re: How to force an unknown state to 0V or 1.8V? Post by Kamal on Oct 6th, 2011, 7:20am Hi Boe, I have following message when I try to use "force" command: ncsim> force {test_Pll.I0.I0.I2.I31.vcofc_out} 4'b1010 ncsim: *E,SETAIA: Analog engine is active. Cannot force digital object: test_Pll.I0.I0.I2.I31.vcofc_out. Any idea of the meaning of this message? K. |
Title: Re: How to force an unknown state to 0V or 1.8V? Post by boe on Oct 6th, 2011, 7:37am Hi Kamal, try Code:
B O E |
Title: Re: How to force an unknown state to 0V or 1.8V? Post by Kamal on Oct 6th, 2011, 8:32am Thanks Boe for your help, you command "run -sync" works. I have a last question, do you know how to release the digital outputs after few nano seconds (10ns)? K. |
Title: Re: How to force an unknown state to 0V or 1.8V? Post by boe on Oct 6th, 2011, 8:39am Hi Kamal, Code:
Title: Re: How to force an unknown state to 0V or 1.8V? Post by Kamal on Oct 7th, 2011, 6:00am Thanks BOE. |
Title: Re: How to force an unknown state to 0V or 1.8V? Post by loose-electron on Oct 29th, 2011, 6:06pm why not use an initial conditions definition? undefined state is not always a bad thing, your test routine probably hits the "reset" early in the test bench anyhow. |
Title: Re: How to force an unknown state to 0V or 1.8V? Post by boe on Nov 1st, 2011, 4:22am Jerry, loose-electron wrote on Oct 29th, 2011, 6:06pm:
- B O E |
