https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> My first behaviour model . A linear voltage. https://designers-guide.org/forum/YaBB.pl?num=1317692770 Message started by zahrein on Oct 3rd, 2011, 6:45pm |
Title: My first behaviour model . A linear voltage. Post by zahrein on Oct 3rd, 2011, 6:45pm I manage to design a VHDL AMS on a linear voltage. The voltage is not linear at all but maybe some improvement on the step size or timing. The behaviour model is equated as V=IR. In this VHDL AMS, i fix the current and vary the resistor. Hence we will get the Linear voltage. The code Testbench module tb_test_ver(); //testbench module name wire pina, pinb; // declaring wire input basic_models_circuit out1 (.p(pinb) ); initial $vcdpluson; //log on vpd file for dve initial #(50000) $finish; //set to run for 50,000ps endmodule //////////////////////////////////////////////////////////////// Verilog AMS module basic_models_circuit (p); parameter real I =1m; real rinput; integer i; output p; electrical p; initial begin for (i =0; i <4000; i=i+100) begin #1000 ; rinput = i; end end analog begin V(p) <+ rinput* I; end endmodule //////////////////////////////////////////////////////////////////// |
