https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> unity gain bw of a push pull aplifier https://designers-guide.org/forum/YaBB.pl?num=1319013134 Message started by mixed_signal on Oct 19th, 2011, 1:32am |
Title: unity gain bw of a push pull aplifier Post by mixed_signal on Oct 19th, 2011, 1:32am Hi, I want to find the ugb of a push pull aplifier. What is the simplest method to do it? Is it gm/cL? In allen Holdberg the open loop gain and 3db pole is calculated. What if I multiply both and get UGB? |
Title: Re: unity gain bw of a push pull aplifier Post by thechopper on Oct 19th, 2011, 5:28am why not? If your non-dominant poles are higher than your GBW then your calculation will be correct. Best Tosei |
Title: Re: unity gain bw of a push pull aplifier Post by mixed_signal on Oct 19th, 2011, 11:48am Thank you thechopper. But what about gm/cL? Will it work? Another method is gm/C1 where C1 is responsible for dominant pole. What about this method? :) |
Title: Re: unity gain bw of a push pull aplifier Post by raja.cedt on Oct 20th, 2011, 12:28am both are correct, UGB=gm/(c), where c is the cap which is responcilbe for dominate pole, so take a amp which has dominate pole at at load so UGB=gm/cl, or consider miller compensated opamp there cc is responcible for dominate pole, so ugb=gm/(cc) Thanks, raj. |
Title: Re: unity gain bw of a push pull aplifier Post by mixed_signal on Oct 20th, 2011, 11:26am Thank you raj! |
