https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> RMS value of ADC output https://designers-guide.org/forum/YaBB.pl?num=1319717738 Message started by singh on Oct 27th, 2011, 5:15am |
Title: RMS value of ADC output Post by singh on Oct 27th, 2011, 5:15am in case of ADC, what is the significance of plotting rms value of output code Vs frequency? does it gives us power spectrum? what is the significance.Please let me know thanks in advance |
Title: Re: RMS value of ADC output Post by loose-electron on Oct 27th, 2011, 4:55pm what are you trying achieve? A digital code sinusoid in vs a sinusoid output? Or something else? |
Title: Re: RMS value of ADC output Post by carlgrace on Oct 28th, 2011, 2:43pm Pretty sure the OP must mean rms output code vs. clock frequency with a dc input. This would give some information on how much clock coupling there is (if the noise isn't flat across clock rate). |
