https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> HSPICE stateye analyse https://designers-guide.org/forum/YaBB.pl?num=1319786646 Message started by haykp on Oct 28th, 2011, 12:24am |
Title: HSPICE stateye analyse Post by haykp on Oct 28th, 2011, 12:24am Dear Forum, Please help me understand what does the HSPICE stateye analyze. I am running stateye on some op amp and there are some parms which I cannot understand in that analyze, those are 1) port instance 2) incident and probe Any book, article will be helpful. Thansk, Hayk |
Title: Re: HSPICE stateye analyse Post by raja.cedt on Oct 28th, 2011, 1:46am hello, is stateye is for serial link simulations or any generic tool? because for SERDES i have used this, but you said for opamps.. how come? Thanks, Raj. |
Title: Re: HSPICE stateye analyse Post by haykp on Oct 28th, 2011, 5:04am Hi Raj, Frankly speaking don't know. I have found some example where stateye analyze is done on some Op-Amp circuit. But if you are familiar with SerDes, then could you please help me understand what is stateye, how to run it and read eye diagrams. ( Like you perfectly explained me in the last time :) ) Any book or article would be helpful. Thanks in advance for you help. |
Title: Re: HSPICE stateye analyse Post by raja.cedt on Oct 28th, 2011, 5:26am hello, Please find the attached doc, which may be helpfull. But could you show me where did you find opamp with stateye. Thanks, Raj. |
Title: Re: HSPICE stateye analyse Post by haykp on Oct 28th, 2011, 5:44am Dear Raj, Thanks for the file. Please see the attached screenshot, where is the test-bench of opAmp on which statetye is run. |
Title: Re: HSPICE stateye analyse Post by haykp on Oct 31st, 2011, 3:24am Hi Raja, Would you please point me some other, more simple, doc where I can read about stateye analyze. Seems I need to gain more basics on this prior reading the attached doc. Thanks, Hayk |
