https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> Understanding DAC SFDR https://designers-guide.org/forum/YaBB.pl?num=1320722090 Message started by analog2001 on Nov 7th, 2011, 7:14pm |
Title: Understanding DAC SFDR Post by analog2001 on Nov 7th, 2011, 7:14pm Hello, I have a basic question about DAC SFDR. I modeled an ideal 16bit dac in verilog-a, I apply an ideal sine wave of 400MHz to an ideal 16bit adc, the adc drives the dac. When I use a fourier transform of the output of the dac, the clock rate is 8GHz, I get -92dB THD. However, if I drop the clock rate to 1.6GHz the THD drops to -6.9dB. I am plotting the 1st 16 harmonics. When I look at ADI, Maxim, NXP etc their input data rate is 1/4 of the clock rate but their dac( which are not ideal) are showing much better results any help will be greatly appreciated thanks analog2001 |
Title: Re: Understanding DAC SFDR Post by loose-electron on Nov 8th, 2011, 4:13am SFDR and THD are two different things. |
Title: Re: Understanding DAC SFDR Post by raja.cedt on Nov 8th, 2011, 7:31am hello analog2001, What's your Question, is it about SFDR or THD? SFDR is about largest harmonic and THD is about all harmonics Any how it's very common to observe SFDR drop at higher sampling rate due to several frequency dependent degradation like o/p impedance of the tail current source, delay variation to current steering switch. In general people are intersted SFRD at frequencies near to nyquist rate. Thanks, Raj |
Title: Re: Understanding DAC SFDR Post by sheldon on Nov 10th, 2011, 5:07am Analog2001, First, what you are saying really does not make sense. Since you are using an ideal ADC, DAC the SNDR will be ~96dB or there is a problem with your models. In addition, an ideal ADC, DAC will not have distortion so why are you looking for it? An ideal ADC, DAC will only have quantization noise. So my suspicion is that there is a testbench or a measurement issue. More details about the testbench and measurement would help to clarify the source of the issue. Sheldon |
Title: Re: Understanding DAC SFDR Post by PW on Feb 26th, 2012, 12:11pm Hi Analog2001, The SFDR is the difference in dB between the fundamental and the higher harmonic. Thus, the SFDR is generaly higher than the THD. |
Title: Re: Understanding DAC SFDR Post by BackerShu on Jul 18th, 2012, 10:50pm Clear answer has been given by raja. Attaching this just in case who check this post later and want to learn more. A very good document on basic definition of ADC from NS. http://robosavvy.com/Builders/limor.bak/ABCs_of_ADCs.pdf |
