https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> assign vs wire command https://designers-guide.org/forum/YaBB.pl?num=1321607746 Message started by newic on Nov 18th, 2011, 1:15am |
Title: assign vs wire command Post by newic on Nov 18th, 2011, 1:15am is there a different to use "assign" command and "wire" command for feedthrough signals?? output out, out_wire; input in, in_wire wire out_wire = in_wire; vs assign out = in; any comment? will the synthesis tool put buffer in between input & output ports? |
