https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> VCO Design Guidance https://designers-guide.org/forum/YaBB.pl?num=1324277864 Message started by lokesh gandhi on Dec 18th, 2011, 10:57pm |
Title: VCO Design Guidance Post by lokesh gandhi on Dec 18th, 2011, 10:57pm Dear all, I am a student of VLSI and new to Analog Design. I am interested to design a VCO, and is looking forward for guidance in this regard. |
Title: Re: VCO Design Guidance Post by loose-electron on Dec 19th, 2011, 1:23pm Take a large block of silicon... Cut away anything that doesn't look like a VCO... :D Suggest you start by doing some basic research. |
Title: Re: VCO Design Guidance Post by raja.cedt on Dec 20th, 2011, 12:34am hello, better read razavi analog design book. It has very good starting on VCO. In fact you can use those ring oscillators in your real time design Thanks, raj. |
Title: Re: VCO Design Guidance Post by lokesh gandhi on Dec 21st, 2011, 8:02am Thank you loose-electron. Thank you raja |
