https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> average noise power https://designers-guide.org/forum/YaBB.pl?num=1324665484 Message started by singh on Dec 23rd, 2011, 10:38am |
Title: average noise power Post by singh on Dec 23rd, 2011, 10:38am i have a transfer function which is multiplied with noise voltage density transfer function (flicker+white noise curve) and i get resulting data from that. So in order to calculate avergae noise power, do i need to take Root mean square of all the values or root sum square of all the values? Please help me on this |
Title: Re: average noise power Post by raja.cedt on Dec 23rd, 2011, 11:34am hello, finally you have to find rms value of the output. but already you have output psd, so just find sum and take square root. thanks, raj. |
Title: Re: average noise power Post by singh on Dec 23rd, 2011, 12:48pm raja.cedt wrote on Dec 23rd, 2011, 11:34am:
thanks for noise voltage density i use eVN2 = eFN2/freq + eWN2; eVN = sqrt(eVN2) suppose my transfer function save_tf_values(j) = variable1; save_output_noise(j) = variable1 * eVN; these eVN values i multiply with my transfer function for each frequency and get data.. eVN is not squared.. so i think i need i need to take rms as shown below? rms = sqrt(mean(save_output_noise.^2)) please suggest whether this correct? |
Title: Re: average noise power Post by raja.cedt on Dec 23rd, 2011, 2:14pm yes, sounds correct. But why u r doing this. |
Title: Re: average noise power Post by singh on Dec 26th, 2011, 1:04pm i have two different transfer functions and i want to see which one has more noise power.. thanx for ur suggestions |
Title: Re: average noise power Post by aaron_do on Dec 26th, 2011, 5:23pm Hi, not sure if I'm missing something here, but why did you divide EFN2 by freq? thanks, Aaron |
Title: Re: average noise power Post by singh on Dec 27th, 2011, 2:33am aaron_do wrote on Dec 26th, 2011, 5:23pm:
efn is flicker noise voltage at 1Hz and the flicker noise gives 1/freq behaviour ... i just took general formula to calculate total noise due to flicker and white noise |
Title: Re: average noise power Post by thechopper on Dec 30th, 2011, 4:10am If intereseted in average noise power, you need to integrate the resulting noise psd at the output. Best Tosei |
