https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> stb and noise analysis fail at 125C https://designers-guide.org/forum/YaBB.pl?num=1325593107 Message started by ywguo on Jan 3rd, 2012, 4:18am |
Title: stb and noise analysis fail at 125C Post by ywguo on Jan 3rd, 2012, 4:18am Hi Guys, I ran dc, ac, stb, and noise analysis for a voltage buffer that is implemented in 40nm LL technology. The stb and noise fail in almost all corners at 125 degree Celsius, but dc and ac analysis have good results. For example, the stb and noise analysis fail at 125 degree Celsius if all devices are in ss corner. But I get expected stb and noise results at 124 degree Celsius. In other corner combinations, I cannot get correct stb and noise analysis results even at 124 degree Celsius. |
Title: Re: stb and noise analysis fail at 125C Post by ywguo on Jan 3rd, 2012, 4:21am This is the correct results at 124 degree Celsius. I think this is probably a spectre model fault. But what can I do to verify it? Best Regards, Yawei |
Title: Re: stb and noise analysis fail at 125C Post by rfidea on Jan 3rd, 2012, 12:32pm Looks definitly like a model/simulator error, or a combination. You should send the test case to either the simulator vendor or the PDK vendor. Usually there is very difficult for the user to know in which the bug is. |
Title: Re: stb and noise analysis fail at 125C Post by raja.cedt on Jan 3rd, 2012, 3:45pm did you check the output file regarding some warnings like some kind of jakobian error, once i got this kind of error which some kind of convergence error, try tp initialize some node may be help full. Thanks, Raj. |
Title: Re: stb and noise analysis fail at 125C Post by ywguo on Jan 3rd, 2012, 7:59pm I find that Operating points had not been recomputed when stb and noise failed. It seemed that the simulator found DC solution for AC analysis and skipped this step for the succeeding stb and noise analysis. Quote:
I select DC analysis and stb only in ADE-L. Now the simulator finds DC solutions for stb analysis and gives correct loop response. Yawei |
Title: Re: stb and noise analysis fail at 125C Post by ywguo on Jan 3rd, 2012, 8:01pm Tools are spectre sub-version 10.1.1.056.isr5, and IC6.1.4.500.9. I choose APS and Auto for Mutlithreading options. Yawei |
Title: Re: stb and noise analysis fail at 125C Post by ywguo on Jan 9th, 2012, 3:26am This problem has been resolved when I replace spectre simulator with sub-version 11.1.0.249.isr2. Yawei |
