https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Change of Temperature during Simulation https://designers-guide.org/forum/YaBB.pl?num=1327313731 Message started by Balthazar on Jan 23rd, 2012, 2:15am |
Title: Change of Temperature during Simulation Post by Balthazar on Jan 23rd, 2012, 2:15am Hi all, is it possible to change the simulation temperature during a transient simulation by verilogA? Thx for your help. |
Title: Re: Change of Temperature during Simulation Post by JulianT on Jan 23rd, 2012, 6:24am Hi, See the http://www.cadence.com/community/forums/T/10265.aspx Cadence forum link, if your running Spectre. Hope this helps, Julian. |
Title: Re: Change of Temperature during Simulation Post by Balthazar on Jan 23rd, 2012, 7:33am Thanks JulianT. I found this Dynamic Parameter in the simulator. It works ... but only with integer values. I tried to use a variable for setting the temperature. The intention is to define a corner set, where the temperature of each corner is set by a variable (e.g. var_temp) which is used in the dynamic parameter setting of the simulator. Example: In Corner1 var_temp = 85 and in corner2 var_temp = -40 In the dynamic parameter setup the parameter "temp" is defined e.g. at t=50us to the value "var_temp". Unfortunately this is not working. Do you have any solution? Is it a syntax thing maybe? Thx |
Title: Re: Change of Temperature during Simulation Post by ywguo on Feb 9th, 2012, 1:11am Quote:
It seems that you want to change the temperature dynamically during one transient simulation, NOT for corners setup in your first post. |
