https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> LDO using verilog-A https://designers-guide.org/forum/YaBB.pl?num=1327986372 Message started by sri.sagar on Jan 30th, 2012, 9:06pm |
Title: LDO using verilog-A Post by sri.sagar on Jan 30th, 2012, 9:06pm Hi All, Actually I need to do behavioral modeling of LDO using Verilog-A. Since I am new to it I thought to get familiar with the process using Cadence SpectreVerilog tool. so I written a Verilog-A code for a simple INVERTER & tried to simulate. I followed the procedure for the below link http://www.ee.siue.edu/~jwade/tutorial/cadence_mixed-signal/ams_tutorial.html I did all the steps in the above tutorial & at the end while I am trying to simulate the schematic I am getting the following error. "The design does not have any interface nets connecting analog and digital components. Interface elements are needed to synchronize the mixed-signal simulators. you must create at least one interface net in the design inorder to run mixed-signal simulation" What might be the problem.?? Can anyone help me in this regard?? |
Title: Re: LDO using verilog-A Post by despap on Jan 31st, 2012, 5:41am If the model is Verilog-A Use spectre as the simulator and make sure to provide view-name(veriloga) is the switch list Please check and update. |
Title: Re: LDO using verilog-A Post by ywguo on Feb 9th, 2012, 1:08am Hi sri.sagar, We even don't know your design. Would you please have more details here, like your schematic, verilog-A code for that LDO? Yawei |
Title: Re: LDO using verilog-A Post by Geoffrey_Coram on Feb 10th, 2012, 6:41am It seems to me in that tutorial (for which you gave the link), the net that connects the dac_driver (which is digital) to the ideal_dac (which is analog) is an interface net. Are you sure you followed all the steps of the tutorial correctly? |
Title: Re: LDO using verilog-A Post by raveendras4a5 on Feb 12th, 2012, 10:17pm Hi, I am sri.sagar's friend & I am doing the actual design. Thank you all for your replay.. 1st In the above Image, I just simulated a small design with 2 inverters coded in VERILOG-A since I am new to it. Now I know the process that how to do with Verilog-A using Cadence Spectre tool. Hi @geoffrey_Coram, I just followed the procedure in that link (tutorial) & tried to do with a small inverter program. I followed the steps correctly, Now I am able to simulate. Hi Ywguo, till now I didn't start with the design of LDO. Hi despap, Yes, you r right I used the "Spectre" as simulator other than "SpectreVerilog"(as shown in that tutorial). & in View Name I have selected "Schematic" So that now I am able to run any of my Verilog-A codes.. :) Now I am going to start with the Actual Design of LDO. I really don't know how to start coding the Verilog-A for LDO.?? Do I need to write the code according to the circuit?? or only for the Equations of gain. load regulator etc..?? Can anyone Help me in this regard. Thanking you. |
