https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Effective Noise Figure of this block https://designers-guide.org/forum/YaBB.pl?num=1328467584 Message started by Multicathode on Feb 5th, 2012, 10:46am |
Title: Effective Noise Figure of this block Post by Multicathode on Feb 5th, 2012, 10:46am Hi guys, Please help me find the effective noise figure of this system. The parallel blocks are identical amplifiers I have attached the file. I dont know how to add an image to the post. I would appreciate your help Thanks |
Title: Re: Effective Noise Figure of this block Post by aaron_do on Feb 5th, 2012, 5:23pm Hi, I think the answer is just "F". Its not difficult to calculate from F=total output noise/output noise due to source. Assume some input-referred noise of the amplifier (Namp for example). regards, Aaron |
Title: Re: Effective Noise Figure of this block Post by Multicathode on Feb 5th, 2012, 6:16pm So you mean to say that I assume that Namp be the Noise input �for the amplifier and then calculate like we do for cascaded stages. I got it. I have a doubt here. In splitter, Will the input noise get splited? �Wat about the inout signal? What I am assuming is that Namp(Noise at ip of 1 amp)=(G1Ni)/4 + Na where Na is noise added by splitter Ni=input noise and G1 is the Gain of splitter and for the signal Samp(signal at ip of 1 amp)=(G1Si)/4 This is the thing that I am doing. Am I doing it correctly? |
Title: Re: Effective Noise Figure of this block Post by aaron_do on Feb 5th, 2012, 7:49pm Hi, The input noise power will get split in the same way that the signal power is split. The splitter itself has no knowledge of what is being fed into it. The splitter is a passive component, so the noise that it adds is only related to its insertion loss. This could be small depending on the splitter you are using. For an ideal power splitter, you can assume that no noise is added. If you are talking about a non-ideal power splitter, then I would have to think about it a bit more. Your equations look to be correct, but how they really work out is a bit unclear since in reality, G1 and Na are related as noise factor is normally equal to insertion loss (for a passive component). I would start with that fact and then simply divide the noise power and signal power 4 ways. regards, Aaron |
