https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> output common-mode of Op-Amp https://designers-guide.org/forum/YaBB.pl?num=1328636207 Message started by gido on Feb 7th, 2012, 9:36am |
Title: output common-mode of Op-Amp Post by gido on Feb 7th, 2012, 9:36am Hello, does the output common-mode voltage of an op-Amp depend on the input signal type and also the magnitude of the input signal. � For example, i got a voltage of -5.137mV using a Sin wave input �whilst it was -397.7mV using a square wave for my transient simulations. Thanks |
Title: Re: output common-mode of Op-Amp Post by RobG on Feb 7th, 2012, 8:46pm Ideally the common mode is perfect, but it is only going to be as good as your common mode feedback circuit. Given that it fails with a square wave I'd look at the outputs individually to make sure the slew rate is the same for positive and negative slewing, but that is just a guess. rg |
Title: Re: output common-mode of Op-Amp Post by raja.cedt on Feb 8th, 2012, 1:26am are you using opamp in open loop, and one more thing when you have sin wave input common mode is -ve is it correct, it does n't make sense for me. One thing just check are you using correct common mode at the input or not. Any how to use CMFB or at least closed loop |
Title: Re: output common-mode of Op-Amp Post by gido on Feb 8th, 2012, 4:58am is the output common-mode voltage of a single -ended op-Amp the same as the offset? if so , then that's what i mean......i got an output offset voltage of -5 mV without any input signal. With a sin wave input, and running the transient, i still get a voltage of -5mV at the output but with a square wave input,i get an output voltage of -397mV.. thanks... |
Title: Re: output common-mode of Op-Amp Post by raja.cedt on Feb 8th, 2012, 7:00am no wrong...i guess what you are talking about is offset (which is the difference between o/p and input common mode, only your case). But how you are quantifying a number by the way, because with signal type it is changing may be your operating point calculation is not correct..any how try to read basic micro-electronics books by razaavi |
Title: Re: output common-mode of Op-Amp Post by RobG on Feb 8th, 2012, 2:52pm Common mode really only makes sense with a fully differential circuit: VOUT = V+ - V- VCM = (V+ + V-)/2 Offset is the difference between the two terminals of the opamp - and it is measured at DC so offset when outputting a square wave makes no sense. I assume you are talking about the average value of the output. To answer your question (again), ideally it shouldn't matter if it is a sine wave or a square wave, but real amps distort the signal so you will see some shift in the average value. I'd guess there is a different slew rate when the opamp is slewing positive vs what it is doing when slewing negative. rg |
