https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Opening Cadence Spectre simulation results in excel https://designers-guide.org/forum/YaBB.pl?num=1328836391 Message started by vp1953 on Feb 9th, 2012, 5:13pm |
Title: Opening Cadence Spectre simulation results in excel Post by vp1953 on Feb 9th, 2012, 5:13pm I was wondering if there is any way to convert the simulation output (which I think is a .trn file) so that it can be viewed in MS excel? Thank you. |
Title: Re: Opening Cadence Spectre simulation results in excel Post by aaron_do on Feb 9th, 2012, 10:39pm Hi, I don't know about how to get the whole set of simulation results but individual plots can be gotten from the calculator...I suspect you already knew that though... regards, Aaron |
