https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> analog design 28nm and below - poll https://designers-guide.org/forum/YaBB.pl?num=1329615909 Message started by love_analog on Feb 18th, 2012, 5:45pm |
Title: analog design 28nm and below - poll Post by love_analog on Feb 18th, 2012, 5:45pm I am curious how people are finding their transistor parameters for analog design 28nm and below Do you still use gm=2*I/(Vgs-Vt). and I=K*W/L*(Vgs-Vt)^2. Working with recent college grads - they just put the structure together and parameterize all the transistors and run optimization routines. This for an opamp with gain, BW specs. |
Title: Re: analog design 28nm and below - poll Post by raja.cedt on Feb 19th, 2012, 1:49am hello, this equations even don't work at 180nm as well...better trust the simulator for finding parameters called gm,gds... and use this parameters to find opamp gain and BW... |
Title: Re: analog design 28nm and below - poll Post by loose-electron on Feb 21st, 2012, 4:28pm For CMOS Academic equations have never worked properly. Academic simplifications. Run a set of bias curves, use those for approximate bias locations (geometry scaling to set Id aftger setting up Vds and Vgs) After that use a simulator. |
Title: Re: analog design 28nm and below - poll Post by weber8722 on Apr 20th, 2012, 7:11am love_analog wrote on Feb 18th, 2012, 5:45pm:
Typically - and independant on process - I am doing normally this: - If you know you need highest speed, use min L, and find W e.g. to achieve a certain Vdsat or drive-strength. - If you know matching is important, then better use non-minimum-L and start with meaningful L, find suited W for good matching, Vdsat and noise. Best make some technology investigations on these parameters vs Id, L, W. - Especially the for current source better use never min-L. Look mostly at Vdsat and matching. - Of course also the Id needs to be selected, just to fit power budget, noise, drive strength, bandwidth, etc. - The more experiences you have the closer usually the starting point on Id, L, W is to the optimum values. Number of fingers, etc. I set usually to make the transistor not looking too extreme, best not far away from quadratic. More care is needed for special applications like RF and power-amps. Bye Stephan |
