https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> how the cmdmprobe works? https://designers-guide.org/forum/YaBB.pl?num=1330528335 Message started by NeilYu on Feb 29th, 2012, 7:12am |
Title: how the cmdmprobe works? Post by NeilYu on Feb 29th, 2012, 7:12am hi all, I try to understand the cmdmprobe in analogLib by raturn ratio method. But I have a question why the pcccs source is added in it. Thanks, Neil |
Title: Re: how the cmdmprobe works? Post by sheldon on Feb 29th, 2012, 5:02pm Neil, Which version of MMSIM are using? From MMSIM 10.1(?), a new component has been released and it is the recommended element for differential stability analysis, the diffstbprobe. The cmdmprobe is still supported for backwards compatibility. Best Regards, Sheldon |
Title: Re: how the cmdmprobe works? Post by NeilYu on Mar 1st, 2012, 7:08am Hi Sheldon, Thank you very much for your comments. I asked the question because I found that the DC loop phase is zero degree(180deg is reasonable). So I try to understand how the cmdmprobe works and I wonder why CADers add the pcccs. Due to the pcccs, the zero degree happens. I just saw diffstbprobe in my version. But the details about diffstbprobe are not available. What's the difference between diffstbprobe and cmdmprobe? Thank you very much & Best Regards Neil |
Title: Re: how the cmdmprobe works? Post by Frank Wiedmann on Mar 1st, 2012, 7:40am The diffstbprobe has the advantage that it also works correctly for non-symmetrical circuits. See http://sites.google.com/site/frankwiedmann/loopgain#TOC-Loop-Gain-of-Differential-Circuits for some details. |
