https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Inversion level factor https://designers-guide.org/forum/YaBB.pl?num=1330549314 Message started by gido on Feb 29th, 2012, 1:01pm |
Title: Inversion level factor Post by gido on Feb 29th, 2012, 1:01pm Hello gurus here, Can someone explain to me what is meant by Inversion level factor(IF) and the formula for it?\ thanks!!! |
Title: Re: Inversion level factor Post by loose-electron on Feb 29th, 2012, 2:14pm care to better explain the context of the question? |
Title: Re: Inversion level factor Post by Dan Clement on Feb 29th, 2012, 6:00pm In weak inversion for mos devices it's the ratio of drain current to saturation current. If equal you are in moderate inversion. Greater than ten strong inversion. Less than than ten weak inversion. Saturation current is process dependent. Normally I have heard this ratio called inversion coefficient not factor but I think it means the same thing. |
