https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Opamp polaritiy https://designers-guide.org/forum/YaBB.pl?num=1330806777 Message started by raja.cedt on Mar 3rd, 2012, 12:32pm |
Title: Opamp polaritiy Post by raja.cedt on Mar 3rd, 2012, 12:32pm hello all, i am reading a patent on charge pump for low spur PLL, find the attached fig. but the basic problem is during M1,M2 turn on opamp has -ve feedback but how about feedback polarity when M5,M6 on. Here i assume tail current source is realized by nmos whose gate is driven by opamp. Thanks, raj. |
Title: Re: Opamp polaritiy Post by Vladislav D on Mar 3rd, 2012, 1:09pm There are two feedback loops here: negative and positive. To make the circuit stable, loop gain of the positive loop should be smaller. This is achieved by the divider, formed by C1 and R1. Looks like, at high frequency, the loopgain of the negative loop increases... |
Title: Re: Opamp polaritiy Post by raja.cedt on Mar 4th, 2012, 12:56am hello, think about dc always, then ac. Thanks, Raj. |
Title: Re: Opamp polaritiy Post by loose-electron on Mar 4th, 2012, 5:22pm The op-amp does not see the high frequency switching. Interesting configuration - You are changing the charge pump current to maintain common mode voltage. Most of the time I have seen the opamp maintain the voltage of the other side of the H-Bridge |
Title: Re: Opamp polaritiy Post by ywguo on Mar 17th, 2012, 7:48am Hi raj. I don't know what's the purpose of that charge pump scheme. But I think One node, like Vx, probably is set to a common mode voltage. So you remove one loop. Yawei |
Title: Re: Opamp polaritiy Post by AnilReddy on Mar 20th, 2012, 12:25am hi raja, if M1 & M2 are turned on op-amp is in negative feedback configuration, if otherwise, the op-amp is in positive feedback configuration... Thanks Anil |
Title: Re: Opamp polaritiy Post by raja.cedt on Mar 20th, 2012, 2:04am hello anil, whats the difference between my first post and your post? |
