https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> verilogA: how to print out number with parametric precision? https://designers-guide.org/forum/YaBB.pl?num=1331033757 Message started by Irvin73 on Mar 6th, 2012, 3:35am |
Title: verilogA: how to print out number with parametric precision? Post by Irvin73 on Mar 6th, 2012, 3:35am Hi all, I want to print out some data from my verilogA code. Let's say for this task I'm using code like: Code:
and get this response as expected: Conversion value: 700.00 (LSB) But the question is, how can I print with parametric precision? I mean if I want change the number of digits after point according to parameter, there is a way to do it? Following straight forward approach (create the pattern string first dependent on parameter, then strobe it) doesn't solve the problem: Code:
I get output like: Conversion value: %6.2f (LSB) 700 It means $strobe function behaves in different way for these two cases for some reason. Any suggestions about possible solution? Thanks in advance. |
Title: Re: verilogA: how to print out number with parametric precision? Post by Geoffrey_Coram on Mar 6th, 2012, 10:41am I don't recall seeing support for variable field widths in Verilog, but since the simulator generally translates Verilog to C and compiles the C into object code, did you try something like $strobe("Conversion value: %*.*f (LSB)", 6, 2, counter_value); ? |
Title: Re: verilogA: how to print out number with parametric precision? Post by Irvin73 on Mar 7th, 2012, 11:00am Hi Geoffrey, Thanks for your response. Unfortunately, when trying your suggestion, I got the compilation error: Encountered unexpected in percentage format command, '*'. Use a valid percentage format command and try again Because for practical resasons the number of different values for precision digits is small (say 1,2,..6), I simply used the "case" statement workaround, like: Code:
Of course it is so nasty (especially if you have a lot of $strobe or $fwrite statements!), but it works. If anyone will share some magic trick to solve it in clean way, it will be good news. Meanwhile I continue with this workaround. Thanks again for your response :) |
