https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> ADPLL spurs https://designers-guide.org/forum/YaBB.pl?num=1331198839 Message started by rfmems on Mar 8th, 2012, 1:27am |
Title: ADPLL spurs Post by rfmems on Mar 8th, 2012, 1:27am If we assume TDC and DCO completely linear, do we still have spurs unique to ADPLL? (except spurs due to SD modulator pattern, which is common to fractional-N PLL) Is TDC resolution a problem? cause the PLL couldn't correct phase error less than TDC resolution. But would that turn into spurs or just noise? |
Title: Re: ADPLL spurs Post by raja.cedt on Mar 8th, 2012, 1:30am no, but Qunatization noise and MASH can create some spurs at high frequency. |
Title: Re: ADPLL spurs Post by rfmems on Mar 8th, 2012, 1:35am Thanks raja.cedt! I suppose TDC resolution is something unique to ADPLL. If the ADPLL fails to correct phase error less than TDC resolution, the quantization error could show up as spurs, am I right? |
