https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Corner analysis description for ADE https://designers-guide.org/forum/YaBB.pl?num=1331547468 Message started by Evgenii on Mar 12th, 2012, 3:17am |
Title: Corner analysis description for ADE Post by Evgenii on Mar 12th, 2012, 3:17am Hi! :) Usually, corners for mos, resistors, diodes, etc are placed in one file. But if I use links to one model file for different devices in my “pcf” (ADE corners file), is doesn’t work… For solution this problem, i generate new file for each device. Is very ugly… >:( What I should do... Thanks! :) For example, what I do… ;pcf file ;corners definition for 0.60um process ;--------------------------------------------------- corAddProcess("060um" "/space/home/eboyarinov/" 'multipleModelLib) corAddModelFileAndSectionChoices("060um" "TS06/tsl060.scs" '( "typical5v" "slow5v" "fast5v" "up5v" "down5v" ) ) corAddModelFileAndSectionChoices("060um" "TS06/passive_model06/tsl060_ggnmos.scs" '( "typical5vgg" "slow5vgg" "fast5vgg" ) ) corAddModelFileAndSectionChoices("060um" "TS06/passive_model06/tsl060_resistors.scs" '( "typ_resd1" "high_resd1" "low_resd1" ) ) corAddModelFileAndSectionChoices("060um" "TS06/passive_model06/tsl060_diodes.scs" '( "diodes" ) ) ;---------------------------------------- corAddCorner("060um" "typ_25" ?sections '( ("TS06/tsl060.scs" "typical5v" ) ("TS06/passive_model06/tsl060_ggnmos.scs" "typical5vgg" ) ("TS06/passive_model06/tsl060_resistors.scs" "typ_resd1") ("TS06/passive_model06/tsl060_diodes.scs" "diodes") ) ?runTemp 25 ?nomTemp 25 ) |
