https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> closed loop direct vco modulation bandwidth limit https://designers-guide.org/forum/YaBB.pl?num=1331823017 Message started by aaron_do on Mar 15th, 2012, 7:50am |
Title: closed loop direct vco modulation bandwidth limit Post by aaron_do on Mar 15th, 2012, 7:50am hi all, Can anybody tell me what I'd the maximum signal bandwidth we could have for a closed-loop direct modulation vco? I'm also interested in knowing the main limitations. Basically I want my output phase to track my reference phase, and I want to know how fast can I expect to make my reference phase change... Thanks, Aaron |
Title: Re: closed loop direct vco modulation bandwidth limit Post by raja.cedt on Mar 15th, 2012, 8:19am loop bandwidth. Thanks, raj. |
Title: Re: closed loop direct vco modulation bandwidth limit Post by loose-electron on Mar 15th, 2012, 11:33am Less than the loop bandwidth. If you want to maintain phase errors low you don't want to be near the edge of the loop BW. |
Title: Re: closed loop direct vco modulation bandwidth limit Post by aaron_do on Mar 16th, 2012, 6:32pm Hi, thanks. Yes I suspected the answer was as simple as that. So can anybody tell me what kind of loop bandwidth is possible and roughly how much power consumption it would take? So I want to actually divide from 2 GHz to some reference frequency (up to me to define), but I need my loop bandwidth to be large. Is it possible to achieve a 100 MHz loop bandwidth? I understand that for an integer-n PLL, the reference frequency is usually around 10* the loop bandwidth. So does that rule out such a simple architecture? thanks, Aaron |
Title: Re: closed loop direct vco modulation bandwidth limit Post by loose-electron on Mar 16th, 2012, 6:41pm Your reference frequency which, in lock, will end up being seen by the charge pump, needs to hit a loop filter where they do not feed through the filter. So, higher the reference frequency the higher you can push the loop BW. |
