https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> PLL phase margin with PSS/PSTB ? https://designers-guide.org/forum/YaBB.pl?num=1334078890 Message started by ellarguero on Apr 10th, 2012, 10:28am |
Title: PLL phase margin with PSS/PSTB ? Post by ellarguero on Apr 10th, 2012, 10:28am dear all, i want to simulate the phase margine of a voltage domain behavioral model of PLL using PSS/PSTB. i got strange results though: here is my schemativ annotated my components time domain simulation works well (strobed) but when i do pss/pstb i get strange results depicted below i insert the probe between the loop filter and the vco i don't know what's going wrong please help me figuring out what's wrong |
Title: Re: PLL phase margin with PSS/PSTB ? Post by ellarguero on Apr 10th, 2012, 12:32pm dear all, i added a pac analysis, the transfer function from the reference source to the output dff is -6.4K dB which means the loop is open !!!! from where may come this probleme, i thought pss take care of the different states of the pfd |
Title: Re: PLL phase margin with PSS/PSTB ? Post by Frank Wiedmann on Apr 11th, 2012, 1:21am I suggest you take a look at http://www.designers-guide.org/Forum/YaBB.pl?num=1189658426. |
Title: Re: PLL phase margin with PSS/PSTB ? Post by ellarguero on Apr 11th, 2012, 9:21am Thank you Frank, What i conclude from the thread you gave is that the models should be smooth, i use transition filter in each of my verilog-a sources and i set both fall and rise times to 1/100th of the period. i think it's smooth enough but the probleme still shows up from where can come this probleme |
Title: Re: PLL phase margin with PSS/PSTB ? Post by Frank Wiedmann on Apr 11th, 2012, 1:19pm Look for the pac signal at all the nodes in your circuit and see where it disappears. |
