https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> How to set up and simulate a switched-capacitor CMFB? https://designers-guide.org/forum/YaBB.pl?num=1334596276 Message started by Jacki on Apr 16th, 2012, 10:11am |
Title: How to set up and simulate a switched-capacitor CMFB? Post by Jacki on Apr 16th, 2012, 10:11am Hello, I am simulating a switched-capacitor amplifier, it is the simple and typical fully differential SC-amp, with the gain of 2. At the beginning, I use continuous CMFB, it works well. Now I am trying to use SC-CMFB as shown in the book (by Paul R. Gray), but I always have the problem of converge for both Trans. and PSS simulation. Then the simulation is crashed. I am using Spectre, in transient simulation, I set the "skip dc", I use "gear2only", also I set ic "all". Does anybody have the experience about simulating SC-CMFB? Thank you. |
Title: Re: How to set up and simulate a switched-capacitor CMFB? Post by boe on Apr 16th, 2012, 10:24am Jacki, A simulator crash is a tool bug. - B O E |
Title: Re: How to set up and simulate a switched-capacitor CMFB? Post by Jacki on Apr 17th, 2012, 9:17am Hello Boe, Thank you for your reply. I solve the problem, because I am using the ideal switch from analogLib, I set the on-resistor and off-resistor as the default value, that is crazy. Now I change them to the reliable one. Spectre works. Jacki |
