https://designers-guide.org/forum/YaBB.pl Modeling >> Behavioral Models >> verilog-A opamp output limiting https://designers-guide.org/forum/YaBB.pl?num=1334972684 Message started by seanpai on Apr 20th, 2012, 6:44pm |
Title: verilog-A opamp output limiting Post by seanpai on Apr 20th, 2012, 6:44pm Hi guys, I am doing an opamp behavior model for my LDO. And when I want to limit my output, there is a error in my simulation. It looks like a discontinuity problem. I don't know how to resolve this problem, so can anyone give me some suggestions? My code is showed below. // VerilogA for lib_cpai_ct369_oa, beh_ldo_hcap_4ct, veriloga `include "discipline.h" `include "constants.h" `define PI 3.14159265358979323846264338327950288419716939937511 `define clip(x,L,H) min(H,max(L,x+(H+L)/2)) //-------------------- // opamp // // - operational amplifier // // vin_p,vin_n: differential input voltage [V,A] // vout: output voltage [V,A] // vref: reference voltage [V,A] // vspply_p: positive supply voltage [V,A] // vspply_n: negative supply voltage [V,A] // // INSTANCE parameters // gain = gain [] // freq_unitygain = unity gain frequency [Hz] // rin = input resistance [Ohms] // vin_offset = input offset voltage referred to negative [V] // ibias = input current [A] // iin_max = maximum current [A] // slew_rate = slew rate [A/F] // rout = output resistance [Ohms] // vsoft = soft output limiting value [V] // // MODEL parameters // {none} // module beh_ldo_opamp_v2(vin_n,vin_p,vdd33,vss33,vout,i50u,pd); input vin_n, vin_p; inout vout, vdd33, vss33, i50u, pd; electrical vout, vin_n, vin_p, vdd33, vss33, i50u, pd; parameter real gain = 810; parameter real freq_unitygain = 557e6; parameter real vin_offset = 0.0; parameter real iin_max = 25e-6; parameter real slew_rate = 17e6; parameter real r2=26K from (0:inf); parameter real ratio=1; parameter real gm_nom= 182.2e-6; parameter real rout=80; //parameter real gm_out= 155e-6; //parameter real vov_p= 149.3e-3; //152e-3 //parameter real vov_n= 335e-3; //156e-3 parameter real vsoft=0.27; //0.67 branch(vdd33,i50u) res; real c1; real r1; real vmax_in; real vin_val; //electrical cout; analog function real ftanh; // define a tanh function for output smoothing input x,L,H; real x,L,H,dv; begin dv=(H-L) / 2; ftanh = L+ dv*(1+ tanh(x/dv)); end endfunction analog begin @ ( initial_step or initial_step("dc") ) begin //c1 = iin_max/(slew_rate); c1 = gm_nom/ (2 * `PI * freq_unitygain); //gm_nom = 2 * `PI * freq_unitygain * c1; r1 = gain/gm_nom; vmax_in = iin_max/gm_nom; end vin_val = V(vin_n,vin_p) + vin_offset; //pd if (V(pd, vss33) >= 0.5*V(vdd33,vss33)) //see as logic conditonal equation begin I(vdd33, i50u) <+ 0; I(vdd33, vin_n) <+ ratio*I(res); end else begin //i50u current flow V(res) <+ I(res) * r2; //equal to V(vdd33,i50u) <+ I(vdd33,i50u) *r2; I(vdd33, vin_n) <+ ratio*I(res); // Vout range if ( V(vout,vss33) > (V(vdd33,vss33) - vsoft) ) I(vout, vss33) <+ ftanh((V(vdd33,vss33) - vsoft), vsoft, V(vdd33,vss33)-vsoft )/r1; else if ( V(vout, vss33) < (V(vss33) + vsoft) ) I(vout, vss33) <+ ftanh((V(vdd33,vss33) - vsoft), vsoft, V(vdd33,vss33)-vsoft )/r1; else // GM stage with slewing I(vout, vss33) <+ ftanh( gm_nom*vin_val, -iin_max, iin_max ); end // Dominant Pole. I(vout, vss33) <+ ddt(c1*V(vout, vss33)); I(vout, vss33) <+ V(vout, vss33)/r1; end endmodule Thanks for any reply. |
Title: Re: verilog-A opamp output limiting Post by boe on Apr 23rd, 2012, 1:31pm Seanpai, you should be more specific about the error you see. A few hints: Why not stick to the example opamp you recently asked about? At a short glance, ftanh and its use look strange to me. - B O E PS: In another thread Forum Administrator wrote on Nov 24th, 2011, 1:24pm:
Title: Re: verilog-A opamp output limiting Post by Geoffrey_Coram on Apr 25th, 2012, 10:45am These lines have no dependence on the input voltage: if ( V(vout,vss33) > (V(vdd33,vss33) - vsoft) ) I(vout, vss33) <+ ftanh((V(vdd33,vss33) - vsoft), vsoft, V(vdd33,vss33)-vsoft )/r1; else if ( V(vout, vss33) < (V(vss33) + vsoft) ) I(vout, vss33) <+ ftanh((V(vdd33,vss33) - vsoft), vsoft, V(vdd33,vss33)-vsoft )/r1; so their derivatives wrt the input voltage are zero. Also, RHS of the contributions look to be equal, but I would expect different values when the output is above versus below V(vss33) + vsoft. |
Title: Re: verilog-A opamp output limiting Post by seanpai on Apr 26th, 2012, 3:29pm To boe: Thank you for your reply. I just begin to use this forum, therefore I may miss some important post rules. I will be more careful in the future. About my code, I have figured it out and will post it in the following for others' reference. (the attachment is the behavior model of this code) ----------------------------------opamp behavior code-------------------------------- `include "discipline.h" `include "constants.h" `define PI 3.14159265358979323846264338327950288419716939937511 `define clip(x,L,H) min(H,max(L,x+(H+L)/2)) //-------------------- // opamp // // - operational amplifier // // vin_p,vin_n: differential input voltage [V,A] // vout: output voltage [V,A] // vref: reference voltage [V,A] // vspply_p: positive supply voltage [V,A] // vspply_n: negative supply voltage [V,A] // // INSTANCE parameters // gain = gain [] // freq_unitygain = unity gain frequency [Hz] // iin_max = maximum current [A] // vin_offset = input offset voltage referred to negative [V] // slew_rate = slew rate [A/F] // rout = output resistance [Ohms] // vsoft = soft output limiting value [V] // // MODEL parameters // {none} // module beh_ldo_opamp_v2(vin_n,vin_p,vdd33,vss33,vout,i50u,pd); input vin_n, vin_p; inout vout, vdd33, vss33, i50u, pd; electrical vout, vin_n, vin_p, vdd33, vss33, i50u, pd; parameter real gain = 810; parameter real freq_unitygain = 557e6; parameter real vin_offset = 0.0; parameter real iin_max = 25e-6; parameter real slew_rate = 17e6; parameter real r2=26K from (0:inf); parameter real ratio=1; parameter real gm_nom= 182.2e-6; parameter real vsoft=327.6e-3; //0.67 or 327.6e-3 branch(vdd33,i50u) res; real c1; real r1; real vmax_in; real vin_val; analog begin @ ( initial_step or initial_step("dc") ) begin c1 = gm_nom/ (2 * `PI * freq_unitygain); r1 = gain/gm_nom; vmax_in = iin_max/gm_nom; end vin_val = V(vin_n,vin_p) + vin_offset; //pd if (V(pd, vss33) >= 0.5*V(vdd33,vss33)) //see as logic conditonal equation begin I(vdd33, i50u) <+ 0; I(vdd33, vin_n) <+ ratio*I(res); end else begin //i50u current flow V(res) <+ I(res) * r2; //equal to V(vdd33,i50u) <+ I(vdd33,i50u) *r2; I(vdd33, vin_n) <+ ratio*I(res); // GM stage with slewing if (vin_val > vmax_in) I(vout, vss33) <+ iin_max; else if (vin_val < -vmax_in) I(vout, vss33) <+ -iin_max; else I(vout, vss33) <+ gm_nom*vin_val; end // Dominant Pole. I(vout, vss33) <+ ddt(c1*V(vout, vss33)); I(vout, vss33) <+ V(vout, vss33)/r1; // Vout range if ( V(vout) > (V(vdd33) - vsoft) ) I(vout) <+ (gm_nom * gain) * (V(vout, vdd33)+ vsoft); else if ( V(vout) < (V(vss33) + vsoft) ) I(vout) <+ (gm_nom * gain) * (V(vout) - vsoft ); end endmodule --------------------------------------code end----------------------------------------- My original question is in the Vout range part. But now I understand it comes from adding a compensation current, which is the function of vout and vsoft. If anyone has the same question, I hope this is helpful for you. Or you can reply me and then we can make a discussion further. To Geoffrey_Coram: Thank you for your reply. It did help to me. |
Title: Re: verilog-A opamp output limiting Post by Geoffrey_Coram on Apr 27th, 2012, 5:46am I had some trouble reading your code; the forum text formatting messes up indenting unless you use the # button to insert code (as I have done). Since you're including constants.h, you should use `M_PI rather than defining your own. I'll also note that your initial_step code won't work properly if someone tries to sweep a parameter (eg, gain), since the initial step block will only be executed on the first point of a dc sweep. There's not that much math in it, so I wouldn't bother trying to optimize the execution. (If your simulator supports it, using localparams would be a good solution.) -Geoffrey Code:
