https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Using monte carlo and histogram for offset in spectre https://designers-guide.org/forum/YaBB.pl?num=1336086243 Message started by skiIC on May 3rd, 2012, 4:04pm |
Title: Using monte carlo and histogram for offset in spectre Post by skiIC on May 3rd, 2012, 4:04pm I am using cadence spectre 6.1.4 and wanting to do a histogram plot after running Monte Carlo. The input is a diff pair part of a sense amp. When I run a transient then to get my baseline number that I think is the offset. i then step it up by 1mV to run with MC. for 100 sample and set my sigma to 3 does this create enough sample for the histogram distribution or do I need more? Then for the histogram what do I use for parameters to show a correct plot? |
Title: Re: Using monte carlo and histogram for offset in spectre Post by sheldon on May 5th, 2012, 9:41am Ski, Are you referring to Virtuoso IC614? Spectre is a simulator. The basic recommendation would be to up version to the most recent IC615 ISR release. There have been a significant enhancements in to statistical analysis tools, in particular, support for confidence intervals and Monte Carlo auto-stop are new for IC615. I think that the issue of the appropriate number of samples to select is complex question, which is why using some of the new tools, such as, Monte Carlo auto-stop, might be useful. Another option is to use one of the alternative sampling methods, for example, orthogonal sampling. Using orthogonal sampling should give better estimates with fewer points. Also since you are simulating a sense amp, you might want to consider using High Sigma Yield estimation since you probably are looking for more than 3 sigma yield. Best Regards, Sheldon |
