https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Using spectreMDL expressions when running PSS analysis (Spectre) https://designers-guide.org/forum/YaBB.pl?num=1336126400 Message started by vivkr on May 4th, 2012, 3:13am |
Title: Using spectreMDL expressions when running PSS analysis (Spectre) Post by vivkr on May 4th, 2012, 3:13am Hi, I usually use spectreMDL for running my batch jobs and make use of MDL's ability to process signals to generate various scalar outputs or run searches. Now, I have found that MDL expressions are not recognized when I create a measurement alias for a PSS analysis, although the analysis itself is run. Does anyone know of a way around this? I suspect that MDL expressions are not directly supported as PSS analysis actually comprises different sub-analyses, such as the initial TRAN until stabilization of the PSS and time- and frequency- domain analysis performed within PSS. Any tips would be welcome. Regards, Vivek P.S: There are very good reasons why I do not use ADE-XL or expressions directly out of the ADE-L GUI. So, kindly do not suggest using one of these. |
