https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Silicon on Insulator deep trench Isolation https://designers-guide.org/forum/YaBB.pl?num=1336700170 Message started by aaron_do on May 10th, 2012, 6:36pm |
Title: Silicon on Insulator deep trench Isolation Post by aaron_do on May 10th, 2012, 6:36pm Hi all, just wondering, for Silicon-on-Insulator technology, does a deep trench in combination with the buried oxide give perfect DC isolation? In other words, does the deep trench extend all the way to the buried oxide and prevent any leakage current? thanks, Aaron |
Title: Re: Silicon on Insulator deep trench Isolation Post by loose-electron on May 12th, 2012, 8:40am go get some specifics on the foundry process - The SOI variants do a lot better than the DT isolation of bulk silicon, but you need the specifics of the foundry process. |
