https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> verilogA: Connecting different regulator on same node. https://designers-guide.org/forum/YaBB.pl?num=1336725145 Message started by fabian on May 11th, 2012, 1:32am |
Title: verilogA: Connecting different regulator on same node. Post by fabian on May 11th, 2012, 1:32am Hi All, I do not know if I am using the right methodology at the moment to model in verilogA a complex regulator built with Series and Shunt regulators. My view is to develop a verilogA model for each of them. Following this method, I need to have a high impedance out model for the disable regulators. So I have defined an internal regulated signal, electrical int_out, out; inout out; V(int_out, gnd) <+ slew(vout,5e6); and I am defining the output impedance such as if (reg_en) res=1m; else res=1G; V(int_out,out) <+ I(int_out,out) * transition(res,0,1u); (line 63) When I run the simulation I got the following message: "... near line 63: Encountered illegal use of both the potential and the flow of a pure probe branch (supply_gnd). Use either the potential or the flow of a pure probe branch, but not both." Does someone see an obvious error on this code? I am using this modelling for switch and it works fine? Best regards, Fabian |
Title: Re: verilogA: Connecting different regulator on same node. Post by Geoffrey_Coram on May 11th, 2012, 8:02am Your error message talks about "supply_gnd" but I don't see that it in the code snippets you posted. |
Title: Re: verilogA: Connecting different regulator on same node. Post by fabian on May 11th, 2012, 9:14am Thanks for your reply. Here is the code and I hope it is less snippet. What I am not getting is that I would like to use the modelling of a switch for the branch b_supply but does not allow me to use I(b_supply) in function of v(b_supply)? Could you recommand me a solution? Fabian Code:
The error message is: Error found by spectre during AHDL read-in. ERROR (VACOMP-2077): "...shunt_reg/veriloga/veriloga.va", near line 49: Encountered illegal use of both the potential and the flow of a pure probe branch (supply_gnd). Use either the potential or the flow of a pure probe branch, but not both. ERROR (VACOMP-1816): Exiting AHDL compilation. ERROR (SFE-91): Error when elaborating the instance shunt_reg. Simulation should be terminated. |
Title: Re: verilogA: Connecting different regulator on same node. Post by Geoffrey_Coram on May 14th, 2012, 5:28am If I combine these two lines: V(int_supply, gnd) <+ slew(vout,5e2); V(b_supply) <+ I(b_supply) * transition(res_supply,0,1u); where b_supply is the branch between int_supply and supply, then you've (indirectly) specified the voltage between supply and gnd. This line: loadres = (I(supply, gnd)==0) ? 1 : -1 * (V(supply, gnd)/I(supply, gnd)); is probing both the voltage and current in that branch, without specifying any constraint on them from within the model. Typically, if you want to measure a current, you are measuring the current through a short -- and then it doesn't make sense to be simultaneously measuring the voltage. Also, on the next line: loadres = transition(loadres, 0, 1u); you're mis-applying the transition function to a continuous waveform. I don't know what the "loadres" is supposed to be doing, but you need a different way to figure it out. |
