https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> TRANSISTORS IN CUT-OFF https://designers-guide.org/forum/YaBB.pl?num=1337036736 Message started by gido on May 14th, 2012, 4:05pm |
Title: TRANSISTORS IN CUT-OFF Post by gido on May 14th, 2012, 4:05pm Hello all, can i make my transistors operate in cut-off just to make use of the high output resistance of transistors in cut-off region in cadence??? |
Title: Re: TRANSISTORS IN CUT-OFF Post by vivkr on May 15th, 2012, 7:43am well, you can! but what would you gain by doing so? I suppose that you want to put your transistors to some good use in your circuit, a task incompatible with keeping them off all the time. Vivek |
Title: Re: TRANSISTORS IN CUT-OFF Post by loose-electron on May 20th, 2012, 10:43am you looking to create a high value resistance? If so results using this method will not be either predictable or consistent |
