https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> VCO swing https://designers-guide.org/forum/YaBB.pl?num=1337705053 Message started by summi on May 22nd, 2012, 9:44am |
Title: VCO swing Post by summi on May 22nd, 2012, 9:44am dear forum, I am designing a vco for my project, carrier frequency=5e9. I have simulated vco alone it is working fine with 700mv differential swing, but the moment i load VCO with a CML buffer oscilation frequency went down to 4.5e9 (expected due to buffer capacitive loading), but swing went down to 400mv i dont have reason fo rthis swing reduction. can any one point out what could be went wrong??? Br, Summi. |
Title: Re: VCO swing Post by raja.cedt on May 22nd, 2012, 10:43am two things: 1. At lower frequency tank Q depends on inductor Q, now frequency decreases from 5 to 4.5, so you can expect reduction in the swing (but i am doubt of large reduction in the swing). 2. One thing i would like to point out is never-ever model cml buffer with only capacitive, you have resistive component also due to cgd leakage. If this is the case it adds huge loss to tank. So please simulate buffer input impedance. If i were you, i will start design including buffer. Thanks, raj. |
